Torque converter hot mode
TD-5
British Columbia Canada
H&S programming enters the torque converter HOT MODE much earlier than the stock programming.
Does the Hot mode converter LOCK & UNLOCK programming override the Tow/Haul mode as well as the normal mode?
I'm trying to write programming that locks the converter immediately shifting into 3rd & 4th in tow/haul mode with OD locked out. I have it so it will not shift into OD, but it appears to follow the HOT MODE settings no matter what I set the tow/haul figures at, Thus my conclusion, Hot mode overrides all other settings?
TD-5
Thanks Mark, Being the 2-3, & 3-5 shifts are highly complex swap & syncronized shifts, is it even feasible to be attempting to lock the torque converter on shift completion with these shifts or am I looking for trouble?
ckrueg
Belding MI
Should be fine. Most tunes lock the converter from 2nd up. And my tune locks up in 3rd through od under moderate throttle.
