TORQUE PRO
wipersnapper_99
Does anyone know how to edit the PIDS on torque pro? I tried to edit my PIDS on torque pro and they will not save. I can test them but I was hoping to get correct data for the OBS 1997 F250. [emoji31]
Sent from my SAMSUNG-SM-N910A using Tapatalk
benjamindurtka
No clue. Thinking about getting one though. Any idea if it tells you egt?
Sent from my E6782 using Tapatalk
CarportMechanic
WA
It will read anything the computer reads.
EGT's will not work for my 2000. I have no idea if the 6.0 or newer trucks have the ability. OBS definitely not. Need a separate gauge for this.
I can read:
EOT
PW
Battery Voltage
Air temp....the sensor that goes into a stock intake setup.
EBP
Load %
ICP
Boost up to 23 ish PSI. Nothing more than the MAP can handle.
There are other things to monitor but these are the ones I look at. Honestly, it was cool for a bit, but I now use it to diagnose and thats about it. For $25 total its worth it. I also use it to read codes on other vehicles we own. So it has that ability also.
For editing, I have an android phone. All I have to do is hold my finger on the screen and it allows me to edit the PID's. When I close out and reopen it has the PID's that were there the last time I closed the app....
kersey1999
LaGrange, Georgia
beginning of the equation insert "(" after the 40 insert ")" then input the following line into the equation:
*(9/5)+32
that will convert from Celcius to Farenheit
