glovemeister
- Joined
- Nov 17, 2011
- Messages
- 131
- Reaction score
- 0
Come again?
Ford?
Dodge?
Duramax?
Wich mirrors are you talking?
Dodge, previous several posts were talking about said mirrors so I thought it was inferred.
Come again?
Ford?
Dodge?
Duramax?
so i have my tow mirrors and bought them with power, I will be wiring the power option in. The only question I have it the metal where the bolts are sticks out quite a bit, how did you guys get them to mount flush? grind it down??
Just to clarify Yoder, did you pull the vent window out and then weld the backside of the plate too? Or did you simple put the plate in there where it needed to be, weld it and then be done? How many of the studs could you use? or did you convert to bolts? It appears I can use 2/3 studs and then I bolt. Not sure what is best to do though?
