Tow mirrors. Quick question
2002FordPwr
Highland Park, IL
Good evening guys,
I looked around for the write up on how to install heated/light mirrors, from a normal tow mirror truck. I could not find it. If someone could please post the specific write up, I would really appreciate it.
Thanks guys
Anthony
Sent from my DROID RAZR using Tapatalk 2
2002FordPwr
Highland Park, IL
Ohh wait buddy, thats for 08 plus mirrors. What about for 6.0 heated/ light mirrors? Is it the same?
Thanks again
Tree Trimmer
what functions do your current mirrors have?
what functions do the new mirrors have?
we can go from there.
2002FordPwr
Highland Park, IL
My mirrors are currently just basic toe mirrors with no heat or turn signals.
The ones I just purchased are from an 03 6.0. They are heated and have turn signals.
Tree Trimmer
your goin to have to get turn,running, and power for the heat out to each mirror.
the connections, is up to you how you do it. i went to a bone yard, and got the door plugs from a 05, cut my door plugs off, put those on, and ran my new power wires to that plug.
or, you cut the plug off your new mirrors, so you can get access to the wires, and just splice them all together, solder and heat shrink.
the power for the heat, you either put a switch inline, or a relay inline. if you use the relay their hot all the time, the switch makes it user selectable. i used the switch, and it should be noted, use a lighted switch, and put it somewhere you can see it getting out of the truck. i have forgotten to shut them off, and came out the next day do a dead battery. i might put a key on relay before the switch in there someday.
as for where to get power for heat, thats pretty much anywhere. turn, you can get that from under the dash if you want. there will be turn and running you have to get to the door. i went under the brake master cylinder, and tapped into the wires that go back to the trailer plug, not the truck. this way, if i was having problems with the lights on the trailer, i could simply turn my lights and turn signals on, and look at my mirrors instead of having to check all the fuses.
if you use that 4 wire trailer wire, it makes running the wire easier as everything is together already, and lets you color code easier under the dash.
take a small piece of reasonably stiff wire, like electric fence wire or welding wire, and run that through the rubber boot on the door, and use it to pull your new wire through.
BigAlsPSD
Pea Ridge, Arkansas
The entire signal assembly can be changed, IIRC around $75 from recon.
There are clips that hold the front cover on. Move the mirror around to release the clips and the front cover pops off.
