Towing mpg thoughts
Dubswyoming
14,000lbs floored. 20lbs boost. Cant make 60. 5.8 on lie ometer. More concerned about the boost number. Is 20lbs correct?
08Monster
More importantly, stock truck, or modified? What conditions is that in?
Sent from my XT1585 using Tapatalk
ckrueg
Belding MI
My 16 hits 25 towing a 7k lb boat not even full throttle so that sounds low
Dubswyoming
What kind of mpg do others see pulling 18,000? My modded 7.3 can pull better and has always gotten 10
tbsimmons
Bakersfield, CA
Depending on the speed and terrain. 7-11. Have not tried going slower to see if it gets better. I don't have long stretches of flat either within 5 hours of me. Everything is 5%+.
gnxtc2
Bergen County, NJ USA
2016 F350 Dually CCLB, remember the duallys have 3.73.
I've got to be around 23k with the 2016. Same trailer, with same load with my OBS, the GVW was slightly over 21k. My OBS weighs 7k, don't know what the dually weighs but anyway.....
Just got my friend's outside of Cincy. Towed from NJ through PA via PA Turnpike to I-70 to I-71. Set the cruise to 70. In OD, I saw 20lbs. If I dropped to 5th, boost went up to 25lbs.
Through PA, mileage was 10.7-10.9. Hit OH, went to 11.1. Mileage on truck hit, 2,000 on the trip.
This is on a stock truck, no tunes, nothing done to it.
Billy T.
gnxtc2@aol.com
Dzchey21
wyoming
my truck is a 12 with a 64mm 15 turbo and with my 12000 lb 37 foot camper I get 8.5-9.5 mpg I'm tuned and ******d I see 30 psi at the most. Your stock 13 turbo wont make much more than that at our altitude.
