Toyo Open Country ATs
drservo
How do a lot of you get so many miles out of these tires? What PSI are you running loaded and unloaded? I'm running 37 13.50 20s, have 22K miles on them and they need replacing I rotate every 5K with oil change. I like the looks and ride of these tires they just don't last on my truck.
verifine
London, Ontario Canada
I had a set before my coopers and got around 35,000 miles on mine before they were toast. My Cooper St Maxx have the same mileage on them now and still have about 1/3 tread
NCSU dirt man
Ft. Bragg, NC
Just going to assume the MT's will wear faster than ATs right? I was thinking AT II as my next set.
yes thats typically true. however we've got a set on one of our fleet's ECSB 6.0 that only has a canned tow tune from an SCT device with basic bullet-proof mods and it will go through a set of Toyo AT-II tires about every 35k. now keep in mind he tows a 4k lb trailer (empty) on a daily basis and when it usually is loaded it's every bit of 12-14k lbs (loaded trailer weight)
Sahrens0202
OH,WY,ND,CO
I have 75k miles on 295-65-R20 Toyo ATII. Got another 10k left. 10,000 lb empty '08 dually, only rotated once. But, less than 10k miles towing anything and mostly hwy miles. Drive like Grandpa, and don't hit the brakes hard.
dsberman94
Pennsylvania
Mine are wearing like dog chit. I've had them 14 months maybe and I'll need a new set by winter this year. Going to squeeze these through till then. Thinking about going with BFG KO2 though.
ckrueg
Belding MI
My at2s have about 30k and have plenty of life left. 20k on the 6.4 and now 10 on the 6.7.
JRLott
TX
I'm pushing 40k on mine. Don't see any reason they shouldn't make it to 50k. I run them at 70 psi. Mostly town, some highway and some loads.
treatcg
Mine are at 35k. Rotated every oil change and I expect another 35k out of them. Most highway miles.
torque beast
48k on AT ll and still got another 10k or so left in them. Stock recommended pressures
