Traction control
WhiteMamba_Scorpion
Alright. It's fuse #54 in the under hood fuse box. If someone wants a diagram of how to build a relay into the system to turn everything off just let me know.
Diagram would be awesome. And that switch with the fuse built in you pictured earlier? Is that a premade unit or something you wired up. I really like it
Bluke
Colorado
The pic above is premade for jeeps. It should work but I think it would be too short because the fuse is in the under hood fuse box.
Using the diagram. Where the spades are just plug them into each slot where the fuse was pulled from. Then just stick the 10a fuse into the inline fuse holder. I would keep the relay under the hood and run one wire from inside the cab.
Hope this helps.
Bluke
Colorado
Also make sure to put the spade with the inline fuse in the hot side. Just take a meter or test light and probe both sides with the fuse out. Whichever side has power need the inline fuse.
WhiteMamba_Scorpion
I could just extend the wires for the spades. Who's it made by I'll look it up. I'm assuming you just drill a hole to mount it to the dash
jcain
Everyone needs to be mindful that you need a normally CLOSED relay if you want the upfitter switch off (down) and the truck to be normal. Once you flip the upfitter up (on) then it'll break the path and disable everything.
to the guys who have done this...does the odometer count when the abs circuit is broken?
charles henson
Hope this helps.
As an industrial maintenance man i totally have this & thx alot your the man,mucho appreciato.:toast:
