Train horn compressor problem, relay?
Strokin6.4
Ok I bought a truck with train horns and the compressor won't come on. The guy I bought iy from said its the relay. Now I looked at all the paper work I got with the truck and I found horn blasters and i found air zenith. Im pretty sure the air zenith is only the gauge and pressure switch, but the horn blasters schematic doesn't show a relay? In the air zenith paper work it shows an 80amp but I cant see where a pressure switch or gauge relay would stop the compressor from coming on. I have crawled up under the truck to look at it yet because of all this white **** I was just seeing if anyone had a clue so I could order one and do it all at once. Thanks
thuglike
Linden, NJ
Gotta be the relay. Check to see if there is power at the relay connection. If not, check your grounds. If there is 99% sure it's the relay. Also there is a key on wire from the relay as well...need to check that...
Strokin6.4
The guy I bought the truck from said he jumped the relay and compressor came on. I was just seeing if any know off hand where or what relay to get?
Zmann
find a warm place LOL
and physically find the relay and test it or confirm it's getting power and a switch signal
if it's bad just order the direct replacement it should have a part #
