89 Stroker
wrong forums...
please delete
please delete
I have seen 60,000 as the interval
but not straight from a Ford Manual
No, it does not, as long as you use the right fluid. MERCON V with NO additives or flush chemicals.
for the E40D, does changing the oil mess stuff up?
Transmission flushes have a bad wrap ( most likely from hack shops using snake oil chemicals ?)
basically they start the truck and let the transmission expel it's old fluid into the machine while the machine supplies clean new fluid to make up for the expelled fluid
so your tranny has no clue anything is going on and it won't dislodge any debris any faster than it would have dislodged anyway
I like to so you can inspect the pan for debris
I also like to inspect or just replace the filter even if it's not required
but thats just Me
MERCON V? Any auto parts store in North America. Plus all Ford dealers, and even Wal Mart.where could i pick up some of this?
