teambluemxer
i have the 5r110. recently its been having to think to go in to reverse or drive. and when it picks itll slam it hard. reverse will like go in and out of gear. any idea?
Sticky solenoids. Old fluid can cause this, when was the last time the trans fluid was changed?
If you are asking what fluid to use, you should only use a fluid that has a MERCON SP or MERCON LV rating. Anything else is likely to result in stuck solenoids.and what fluid can i get huge bulk in
You can flush this trans only with a heated flush machine. They exist, but they are VERY rare. Most places have never even heard of one.
You can change the fluid in the pan, drive it, and change it again.
I have no idea what this means:
You guys with direct solenoid issues, let me know if I can set you up with our modded solenoid.
A lot.
