Trans Pan
cornbinder7.3
Catawissa, Pa
I have a 2001 F350 DRW pickup with 103K on it and pull a trailer with a antique tractor that is 10K I had on a scale at a truck stop and combo weight is 24k and I have a deep trans pan to put on should I do it or won't it help much I have the big 6.0 trans cooler on it now and it don't run too hot as I trans temp gauge also I have 4.10 rear axle what is you thoughts on the deep pan thanks
Jomax
Arizona
If you have the pan already, I say throw it on. If you are wanting to BUY a bigger pan, I say save your money, As it won’t help.
Mark Kovalsky
SE Florida, USA
If you want the bottom of your truck to look pretty, put the pan on. That's the only benefit from a deeper pan. It won't help cool your transmission.
