Transmission issue
Joshf250
Truck just started doing this when you are in drive and sitting at a stoplight and have your foot on the brakes the truck feels like it’s trying to push through the brakes and then if you shift into neutral and back into drive or reverse the motor seems to die down and rev back up. No shift flares, no harsh shifts, no shutter, nothing else is acting up. Truck is a 2016 had since brand new
8WR_ZJ
What are the codes for the check engine light?
Sent from my SM-G965U using Tapatalk
Joshf250
Fuel trim bank 1, but my transmission line pressure is going to 120psi when in drive or reverse just at idle. Thinking maybe a valve or solenoid sticking open in the transmission.
gotchadollar
Mine was doing the same thing, these were my clutches.
Joshf250
Was it just burned up clutches or were they froze together?
gotchadollar
The clutches were just burnt, mine did exactly what yours was doing then i would rev it up in drive and it would lock in 5th gear so i was still able to move it.
