Truck Electrical Problems??
So this truck is going to be the death of me!! I ran buzz tests and cylinder tests on it buzz tests sometimes sound fine and cylinder contribution test come back saying #5 is bad then I run the test again and it passes and then I did it like 2 other times and it did the same thing. Then ran it again and said that #5,7 were bad. Thought that it was my injector so I put a new one in. To no avail. Switched Idms with an old one. And I have replaced the uvch with an old one. Still does the same thing. Truck runs like its missing sometimes and then sometimes it runs great!! Do you guys have any ideas??
Ok I will do that. And I believe that it is the ford cps. I switched number 7 injector and number 5 injector because at first number 7 wAs being bad. And when I did the switch it said that number 5 was bad. So I sent that injector back to rosewood and had him fix it. Now it's still doing the same thing and I know that it's not the injector because it's brand new.
Lethalthreat7.3
Denver, CO
I did a big write up on almost the exact same issue only it was #2 and sometimes 4. Got it to fail a cct once then never again.
Replaced the uvch and gasket. Ohm'd each injector and verified the reading was the same at the 42pin connector over the drivers valve cover.
