Truck has 238/200 injectors 38r billet turbo and arp studs. Also has 300k miles on it with original headgaskets.
Truck is blowing water out of the coolant tank as soon as you start it up. It even blew the capoff.
Almost zero pressure in the crank case. Oil is not mixing with the water. No smoke out of the tail pipe. Water in over flow tank is clean. Truck runs ok. Little power loss. Slight miss to it. Little rough.
Any ideas? Head gaskets?
