Truck randomly died tonight.
farmall99
McMinnville TN
I was sitting at a red light this evening, changed tunes on the chip and the truck just dies. It would just crank over and never hit a lick. We let it sit for a few minutes and it fired right off like nothing was wrong. Am I right to think that it's something electrical or what else could it be?
HaysKSFirefighter
Valley Center, KS
Check the chip and make sure its tight? I had one that was a little loose that would do the same thing. Might want to check it cause it will fry your pcm if it wiggles loose
Arisley
Arlington, Texas
I am thinking chip issue. Might have gotten a minute amount of corrosion on the contacts. Usually pulling out and reinstalling the chip will fix it and will leave you looking :confused: but :redspotdance: . Do yourself a favor, grab a scotch brite pad, hit the connector on the PCM a time or three. Do the smae to the chip. Reinstall, and feel good about fixing the issue.
