truck shut off then low oil pressure
Str8Ugly
Odessa Tx
so yesterday i was driving home, i have EGR delete, with a sctx4 from nolimit no clue on whose tunes, so i started to pass somebody got around them when i did truck shut off, then once i got on the shoulder of the road low oil pressure light came on. tried to start the truck just turned over with no start, so i turn the key to off. look under the truck for oil dripping or any signs of a leak nothing so i check the oil, oil looks fine. get back in the truck try to crank it and it cranks right up, still no check engine lights. when i get my oil changed again ill be sending it off for an oil analysis. anything else i should get it checked out for or could it just be a fluke?
Str8Ugly
Odessa Tx
nope everything operated as normal, no lights came on for the rest of my hour drive home, nor did anything happen on my way to work, which is 1.5 hr drive, plus my truck idles all day long too
