Truck won"t rev up!
Spickerman6.4
Factoryville Pa
Last weekend i did 30% nozzles high rev valve springs and lifters, push rods, 6oh manifolds. Took truck for a ride was turning rpms very slow, had little miss to it. Now it won't go past 1800 rpms. im waiting on tunes from innovative to see if its a tuning issue but wanted to see if anyone had any input on this.
Spickerman6.4
Factoryville Pa
Yeah bleed it all out but it still seems like its starving for fuel. Eric is back in his office on Monday hopefully get the new tune and hope that's the issue
Sent from my DROID RAZR using Tapatalk
Spickerman6.4
Factoryville Pa
Yeah it does so I'm just gonna wait till Monday for tunes for my nozzles and such and see what happens and go from there
B585Ford
WV
Were you getting any smoke when taking off? If you were getting plenty of fuel (which I am guessing you are not) on 30%s nozzles, when taking off, I would think you should be getting some smoke.
Spickerman6.4
Factoryville Pa
Well guys found out the problem VGT module crapped the bed. Got it all back together last night took it for a ride and all I can say is oh my god! Stock fuel pump had no issues keeping up with 30% nozzles as i can tell so far everything looks and the sounds with the 6oh manifolds unbelievable. very pleased with the build so far dyno run soon to see results.
Stroked777
Casper, Wyoming
What pw tune you running and was it holding at 24k-25k?
Spickerman6.4
Factoryville Pa
I'm running 330 extreme x tune from IDP not sure on rail pressure yet my SCT live wire doesn't read rail pressure but from what I can tell it had no issues running them. Very snappy and quick response
B585Ford
WV
The LW will read RP in kPa.
If you can, find out the PW of that tune, especially if you are maintaining 30%s.
pog
psa
i bet its dropping rail pressure. hard to tell without monitoring it. the power is probably up but rp is most likely down.
