Tune DPF on
theplumber
I want to know if one of you here
Have tune their truck whit DPF on and if yes
What is the best tune or tuner ?
Thanks a lot for your help.
Envoyé de mon iPhone
theplumber
If i leave my emmission on .
Did i have to check the EGT or the sensir are alerady there ?
UNBROKEN
Innovative Diesel for DPF on tuning. I was able to watch EGT on my Edge CS using the pid for the factory pyro with no problems.
Jassman
MS
I have ID as well..works flawlessly, shifts smoothly, has low egt's... and I'm actually seeing better fuel economy in Eric's aggressive street tune which has more than enough power. I drive it easy and am seeing between 15.4-16.2 on a tank of diesel with a 6" lift and 37's.
Powerstroked162
On Da Juice
Wa. State
And Regen ? A lot or normal?
Regen increases with the aggressive tuning, enough to notice... I doubt it. I used Eric for my DPF on tuning during some product testing and it was a healthy addition over power over the superchip tuner we were using. I think you'll be happy with it on a stock turbo. You'll experience issues with modded turbos from there. Let me know if I can help. Eric's tuning and my cold air intake kit made good power
Preturbo?
Correct. There is a pyrometer in the passenger side uppipe from the factory. The remaining two EGT probes are in the dpf.
theplumber
Whit my 2014 it was tune whit gearhead and damn it was nice .
theplumber
My problem is i am in canada and the money exchange are really bad .
I will have to buy tuner in canada cause now its 30% money exchage.
But i can buy the tune from innavative diesel and the tuner here.
I am not sure between the New livewire ts+or the bully dog car i really like the switch on the fly
theplumber
I am not sure between the New livewire ts+or the bully dog cause i really like the switch on the fly
Jassman
MS
do a little research..I believe SCT bought BD..and even though it might be on the fly the tunes are still the BD tunes and from what I was told are no where as good as the SCT tunes or even better the Custom tunes from ID.
UpstateDieselGuy
Mayfield, NY
Custom tuning is always better. That being said, the new Bully Dog units Ford tuning is SCT tuning now. Granted, it is still generic stock equipped truck tuning, but it is SCT. I'm Thinking about the GT myself with custom tuning as I like the physical size of it. At this time, only the preloaded tuning will be switch on the fly. Any custom tuning will have to be loaded individually just like any other SCT device.
