turbo drain help
Fordtrucks
Haven't confirmed yet, but I think my new oil leak might be a turbo drain. Just did everything from the heads up, including a stage 2 intake manifold. One thing the mechanic helping me out noticed the new manifold didn't have the bolt studs sticking up like the factory manifold so the turbo drains weren't bolted down like there supposed to be. He wants to know what were supposed to do with them? He used a pry bar to push the drain up into the turbo the first time but that must not be working.. Please help.
Fordtrucks
Well were not sure yet. I gues that's the only one with a drain that's not bolted down anymore..
SlowSmoke
Sylvan Lake, AB
The steel line should hold itself up into the drain port. Is there a chance the oring got cut while installing. It can happen pretty easily to the Atmo turbo if you jam them in. If you don't know which turbo it is, I would start with nailing that down first.
