ohiostroker95
I have a 2008 6.4 with ARP head studs, S&B air intake, Fass 150, EGR is been removed, ladder bars, running a H&S xrt, mishoto radiator, and a stage 3 built transmission. I'm looking to go with a single turbo and would like to do some bigger injectors. What single turbo would you guys recommend? I also see mostly just the bigger injector tips for the injectors, is there anything wrong with going that way instead of a whole new injector? The stock ones should be fine since the engine only has 11,000 miles on it. And I'm aware of that you need to upgrade the injection pump when you go with bigger injectors, which injector pump would you guys recommend for that? I'd like to be around 800 horse is my goal for right now. Any help would be appreciated. Also who still does custom tunes that would be able to help with getting it tuned once everything is done with it ?
Thanks!
Thanks!
