Turbo install tips
MEDIC350
Michigan
Get a second hand to lift it out.
Be carful not to damage the O ring on the metal coolant pipe.
You may have to remove the exhaust manifolds to remove the up pipes
Cover all intake and or exhaust manifold openings when they get exposed
It's a tight squeeze to get the turbo out but it will come out.. It's easier if there's no egr.
dsmracing1
Alberta, Canada
I've heard from others to pull the waste gate actuator off the turbo which makes pulling the old one out pretty easy....
Biggpigg4x4
I think the h&s turbo kit instructions had torque specs. I used those instructions to remove my stock stuff and for some.torque specs
Cheap6.7
Rockisland County IL
Hey cheap, i see your not to far from me, just when you get your kit, just bring it on over and well knock both of our trucks out in a weekend!
Lol not a bad idea but I got days at work I need to burn up during a week it is nice outside. And I wana say I did that when it's done.
What kit did you get?
