Turbo upgrade diy?
08strokerr
So I have been looking at upgrading my turbos when doing my up pipes. I'd like to go 71/59 from elite but I have found where I can buy the 71 and 59 batmowheels by themselves for 800. Is all that's done to elites turbos just a rebuild and machined out to fit the bigger wheels or is it not that simple. I was thinking I could do the machining myself as I work at a machine shop but if I'm overlooking something then I'll just stick with buying them from elite.
Breaking Habits
Mapleton, Illinois
The profile of the 59 and the 71 being used is 4 year old technology. Elites 59mm and 72mm wheels are different and make more power. Buy the elite chargers. Don't forget. Tadds 59mm has a bigger turbine as well
Lipka101
Maryland
Has anybody done this though? Is that all it is, just machine the housing to fit a bigger wheel? I get you need to balance the assembly too.
f350guy
Texas
I have on other vehicles that have a specific turbine inlet flange and a decent turbine wheel already.
It was nothing more than a good rebuild ($300-500 depending where you go and the quality of the balance), plus the cost of wheel, machine time for the compressor housing and/or backing plate.
The one I built for an older BMW ran $850 delivered with a coated turbine housing and billet wheel, including a 360° bearing upgrade, full balanced, and machine work. For this car, the only other wheel people have ran (aside from stock) was a 60-1 Garrett wheel. Works well but I went with a GTX3582R wheel. I took a guess as what would work better from what I have seen and examining compressor maps.
You are paying extra for the R&D of the company (Elite, RCD, etc) seeing what works best with what setups. Will a 71mm Batmowheel make more power than stock? Probably so. As much as the 71mm from Elite with the Precision wheel? Doubtful.
Would I spend the extra $500 or whatever for a known, proven, dyno'd turbocharger from one of the large companies? Yes. Knowledge is not free.
Lipka101
Maryland
Makes sense. Just curious if anybody has tried it.
