Turbo/Y-pipe clamp was loose
purpleheart350
Rokwall, Tx
So I havent been inside my engine bay for a while, did have a need to. After I put my front bumper on, full replacement, my truck seemed a little slower I didnt know if it was becuse it weighed so much. I know I have a slow leak in my powersteering box, so today I went to put power steering fluid in. I pop the hood go straight for the cap, fill it then recap. I figuered since I am there I would just check and make sure everything is tight. I look up and the clamp to the turbo and y-pipe is as loose as a pron star. and of course there was a small gap there which now I know why I have been running at 7-10 psi so the past 2 months. Anywho should I be worried about a lot of damage if any because of this? It starts up fine and runs like normal everytime just little weak but is back to where it used to be. Now I know to check every once in a while.
Tom S
I think you will most likely be ok as it was post turbo.
