Twin Turbo setup...
Extended Power
This setup was on my truck for only two weeks.
I have sold the primary charger, but I have a bigger one coming. (If you want it, you have to pay what I paid for it, or buy another Borg Warner S480 style charger)
I would like to sell with the secondary, as the piping is all fabbed up to use it.
I just ordered a billet 64mm compressor wheel, and cover for it, along with a spring style waste gate actuator.
All piping has High Luster ceramic coating, inside and out. (Except the downpipe, it is only painted with high temp flat black.)
The BD Power diverter valve adaptor flange is also ceramic coated with a 2000*F+ coating inside and out, and port matched to the T3 flange gaskets.
Secondary turbo is a Borg Warner 66/71/.80 and I also have a .70 A/R for it...along with the billet 64mm wheel and cover, your options to making a turbo are: 64/71/.70, 64/71.80, 66/71/.70, and a 66/71/.80.
The Sound Performance Quick Spool Valve is also available yet, but can separate it as well.
This was on my 2003. I fabbed the piping so the A/C did not have to be moved.
This also comes with an intake elbow I made which has a V-band connection on it, so no hoses to blow off at all. In fact, the only hose connections are on the intercooler, which allow for engine movement, and the discharge off the primary charger. (Which should only be 30-40 psi max.)
Lube lines for both turbos, and special adaptor for the oil connection on the engine is included.
BD Power Diverter valve, pedistal and drain line are all included.
Will sell with my modified up pipes, which has no EGR connection, and are also ceramic coated, and had the bellows replaced with stainless steel expansion bellows from Irate Diesel.
I will part this out, but I need buyers for everything before I do. So if someone wants the turbo, call your buddies and have them buy the piping, and Diverter Valve and pedistal.
Turbo: With 64, and 66mm wheels, 64, and 66mm covers, and regular wastegate actuator, as well as the spring style actuator. $1300.00
BD Power Diverter valve, pedistal, drainline for T3 turbo: $700.00
Twin Turbo Piping: $2500.00 includes mounting plate, and all piping etc.
Please PM me with any questions.
Extended Power
More pictures:
Extended Power
More pictures:
Also...comes with the rubber intake elbow, and new AFE filter element.
Extended Power
What direction are you going now?
Commomrail with Allison...
How well did it run?
Who ever buys the turbo will need to enlarge the wastegate ports in the exhaust housings...I had over 100 psi drive to 80 psi boost...thee 'ol Victor Reinz head gaskets let loose...:blah::blah::blah:
With the 66mm wheel, to me...and I am VERY picky...it was a little slow on the street if you didn't drive a little agressive. If I puffed black smoke when leaving a light...it was good...but I drove like a Gramma...it was a little slow, hence as to why I bought a 64mm wheel and cover for it.
Extended Power
Ivan what do you think freight would be across the border for the tranny?
What I could do is take it to Havre, or Great Falls, and ship it from there.
A couple years ago, when I had a guy wanting my stock transmission, it was like $500.00 from Canada to him down in Texas.
I know it would be way less then that.
Extended Power
Hey guy's...Here's an option:
I work shift work, and am away from home alot of the time, so if there is something you really want, I will accept half now, and the other half at the end of the month, if that works for anyone.
Works for me, as I won't be able to ship till the end of the month, and gives people time to save up if required.
I posted things now, so you can think about it. Cuz if I waited till I came home again to post things up.....I would be back at work again before I could ship it out.
Matt
Minnesota
Great looking set up, Ivan. I mean everything looks clean enough to eat off. Good luck with the sale.
