http://powerstrokearmy.com/photopost/data/548/medium/Diag.jpg
Morgan...and others...teach me here.
On a regulated fuel system (regulated supply or regulated return)...pressure is only regulated between the source of pressure (the pump) and the regulated restriction (regulator). I'm assuming you set the pressure on a Airdog/Fuelabs/etc systems (never had one, please excuse if I'm not understanding how these are setup exactly) while the truck is at idle.
Without a regulated return how do you guarantee what the HPFP supply side fuel pressure is during high fuel demand operations? I'm not seeing how a regulator between the electric fuel pump (Airdog/Fuelab/etc) and the HPFP would compensate and ensure the HPFP ALWAYS sees 8-10 psi (or whatever the desired pressure).
I understand fuel temp concerns....but as long as the return pressure isn't cranked beyond the spec you want the HPFP to be supplied with in the first place....I'm not seeing how this creates a situation with less fuel being moved by the HPFP.
Have you monitored HPFP supply/return fuel temps and compared them on a regulated supply vs a regulated return type systems? If so, any data you have to share would be great.
Thanks in advance for the insight/perspective.
