Up-pipe bolt. I need help!
mpowerstroketwins08
saskatchewan
I stripped the bolt on back of the turbo. I tried new sockets. And this thing. I am out of options I need the turbos out ASAP. ANY SUGGESTIONS
Sent from my SM-G900W8 using Tapatalk
pooter
marietta,ohio
I was able to pull one up pipe out with the turbos when I rounded off a bolt head. I also have custom up pipes and had another person helping
JuststrokeIT
I don't know which bolt you cant get off but when I did my 1st cab on pulling the turbos I rounded one out as well. I managed to get a torch in there it was a tight fit and I had to watch out for things but I just went in and torched the head off the bolt. pulled turbos and then heated the flange and pulled the remainder out with vice grips a lot better than snapping it off in the flange and having to drill.
mpowerstroketwins08
saskatchewan
