up pipe egr provision question
Strokin_4_Life
Yorkton SK
will the egr delete exhaust plate work up behind the turbos where the egr provision pipe connects? I wanna get rid of that pipe when I change turbos. Also can I remove up pipes cab on?
thanks!
powerstroked08
Pennsylvania
Ok the reason I asked is because your going to have to relocate your EBP sensor. Its located in your egr up pipe, so you will need to move the tube and whatnot to the plate.
powerstroked08
Pennsylvania
could I tap it into the drivers side up pipe? thanks for the info
I wouldn't do that man. Just tap the block off plate for a fitting to hook up the ebp tube to and put the tube and sensor there. I have 6.0 manifolds so I have the sensor there. But a few guys on here have relocated the tube and sensor to the plate with no problem.
Strokin_4_Life
Yorkton SK
alright man thanks for the pointers
