upgraded idm??
lsmith33
Katy, TX
how hard is it to upgrade idm from an early 99 to a late 99? mine took a sh!t an if im replace i rather upgrade also
Russ
The voltage is the same, but there is something different between the OBS and the SD IDM's. Us OBS guys swap up to a SD IDM and it smooths out the idle some, and gives a tiny amount of better throttle response.
TARM
That is correct they are not all the same voltage. Depending on the year of the IDM will be either 100v, 110v, or Then you have aftermarket upgrades ones with the resistor that takes them to 140v.
Honestly is a 2 second google search that hard.
