superduty4x4
Pretty sure mine is dying a slow death- power brakes aren't working so hot and the AC blows out the defrost vents until RPM's come up. The pump is also making more noise and there is a buzzing under the dash that goes up/down with rpm.
Question- will a failing vac pump cause the e-brake light in the dash to come on? Since this problem started the e-brake light has been on also. At first it was intermittent, now it's on all the time.
