Vape box mod: 20a raptor w/variable voltage
MrOneEyedBoh
So long story short, my cousins wanted me to make them some box mods for vaping. I bought parts in bulk, thus leaving a few boxes left over. There's many ways to build these but I did my own thing. These are heavily potted because of the high amperage. Just a personal choice, some don't pot at all. Potting isn't going to hurt it, it just doesn't look as pretty inside the box lol.
They are 20amp ( yes, 20a ) dual 18650 mods. They have the Raptor chipset, utilizing dual fuses along with reverse polarity protection and zeners. Also includes dual capacitors off board as well.
The boxes also have a digital voltmeter that reads both actual battery voltage ( shows battery life basically ) and it can show actual vaping voltage that you selected. The selector switch doubles as a lock out switch to prevent accidental firing in your pocket. The switch I an on-off-on slider switch.
Voltage is user set by utilizing the top mounted potentiometer. Low is ~3 volts to 6.0 volts. These builds work VERY well on a sub-ohm parallel or dual coil at around.5-.6ohms.
They also have the standard 510 connector with the larger standard push to fire switch. The switch isn't a cheap plastic body, these are metal switches.
Since these are handmade, there are some slight imperfections here and there. Nothing major by any means, but I wanted to put that out there.
You're going to want some good 30a batteries that are true high drain for this mod. Battery choice really makes these shine.
I've tested them and they are ready to go. Obviously with anything electrical, there is no warranty. But I guarantee they work just fine. I also have some no nicotine juice I bought to test these out I can throw in with the sale. I also have the atomizer tank, 24 and 26ga kanthal wire plus (2) genuine Sony VTC3 batteries. So basically if you're looking to get into this, I can set up only one complete package.
Price is 180 plus shipping. Or if interested in the package deal , we can work something out. I'd even do trades possibly.
Nj67
South NJ
Where u from man? Im very much into vaping. Mostly high end like glas or zeros. Probably not gonna get $180 when a 165 watt ipv3 is onlt $110.
ghohouston
Lewisville,Texas
Vaping is the action of smoking an e cig. An e cig is a battery powered device, with an atomizer (coil), that is basically submerged in e cig liquid. The liquid (if good quality) is vegetable oil based. Nicotine can be added if you please. It's supposed to be a healthier alternative to cigarettes. The pothead have had "vaporizers" for a while, but these are a bit different. Anyhow, vaporizing vs burning, vaporizing is supposed to be easier on the body...
MrOneEyedBoh
True but Chinese engineering, vs quality USA parts from mouser. Its all good. If I can get someone into vaping and I can get more than two sold,I'll cut my losses and give a good deal. Hell if someone takes them all,I'd do the same.
Nj67
South NJ
If you're willing to send me one to test i can get it to my buddy who owns a shop. He likes to support guys like you that build mods. How many watts is it? If i remember right the craze about the raptor was 120w when they came out. Im interested in more pics of the internals when you get time.
MrOneEyedBoh
I dont build them. Its an overbuild that I had to do to make it worth it for my family. I had to build 8. I messed up on one, and the other 4 are left. I cant send one to test, as I dont know you lol. I dont want to be out money. The internals are all heat shrinked and then epoxyed/hot glued on top. Some builders DONT do that, but I did it because Im using high drain batteries, the raptor is high amperage/wattage. I mean why not? The only thing it does is make it look not as pretty. But in the end its to secure the wiring and keep it from chafing/moving around/solders breaking loose from constant movement.
If you want pictures I can give them to you. I guess by cellphone?
TyCorr
So nobody pulls a pack of.camels out of their pocket and fires it up anymore?
Nj67
South NJ
I understand bud. The cheap chinese manufacturers shrink wrap things nowadays also lol. Apoxy too. Google 9southvapes. ... u wouldn't be out money. If anything we'd make u famous lol. GLWS
