cw96stroker
So I finally got my bts in my '01 that has been setting in the shop for quite some time now and now have a vibration. I bought the trans used off a member on here and I do think the trans is ok. The vibration is BAD from about 1500-2000 rpm under a load. So first off I have replaced hub lockers (which i was badly needing, front left would lock in on highway) carrier bearing(was needing), checked u-joints, and rebalanced tires. Still vibrates horribly going down the road under a light load at these rpms.
Now setting still I have noticed that it idles a bit rougher than it did before, and also vibrates at 1500- 2000 rpm but not near like it does going down the road. Feels very similar to bad u-joint. Vibration was not there before I took the old trans out. Im now thinking some how its something to do with the torque converter, or in that area (and I have double an triple checked the bolts and they are tight). Any Ideas?? Also tc is a precision and it came with the trans.
Thanks,
Thanks,
