Vibration
Lsutigerjr
I recently put a new set of tires on my 2003 f250. That's when I noticed a vibration. When I let off the throttle it coasts smoothly. When I get off it seems smooth. Its when I'm at cruising speed that the vibration is at its worst. I changed the center support bearing but the vibration is still there. Any suggestions on where to go next in my troubleshooting? I'm thinking ujoints. But the vibration seems to be coming from the front half. ??????????
Sent from my HTC One mini using Tapatalk
raptor
Oregon
if your ball joints tie rods and track bar are in good shape you might try road force ballencing them or have your drive line checked
Lsutigerjr
Got under and beat and banged. Think I found the problem. Ujoint is loose so I'm swapping them out Friday.
