rockhardhoosier
My glow plug light not working on 2005 ,6.0, can you tell me which fuse to check, or relay, thanks
I know where the glow plug relay is located , trying to figure out if there is a fuse like there is on the 7.3, or just the relay , I have been searching, kind of figured that's what this sight is for .Trying not to be "that guy" but all you have to do is search around a little bit.
Even Google images.
No sir, just had a bunch of work done to truck , it worked when I left just quit couple days ago, just trying to find the fuse # if there is oneDo you have a owners manual?
Even Google images.
Well do you have a voltmeter or test light?
Yea I knew the relay was on passenger valve cover , that's what I was trying to find out if there was a fuse or fusible link, I got a manual , but it started working today , so must be a short or loose wire, thanksIt's been a while since I messed with a 6.0 but if my memory serves me correctly, there is a fusible link, I don't believe there is a fuse in the box.. I had the same issue as the OP, I ohmed out the circuit and found bad gp's and the harness was wrecked..
