Wastegate setup and up-pipes
91turbogsx
Gardner MA
I'm in the need for a wastegate setup and new up-pipes for my company truck. Factory up-pipes just started leaking shortly after getting the level 3 Spartan license. It's been getting a workout in the 310 tune. LOL
My question is would it be easier to pull the tranny or lift the cab to install these items? Keep in mind pulling the tranny is more feasible for me. Would I be able to even install the wastegate setup with just the tranny out?
What would you guys recommend for a setup? Any vendors feel free to PM me offers. Looking for a intake elbow setup and IC pipe as well.
Thanks
91turbogsx
Gardner MA
Don't need to pull the tranny or anything? I called the dealer just to see how they would replace the uppipes and they said they remove the tranny. And I talked to Ben at Rudy's and he laughed when I said I'd like to do it cab on. LOL
SEABEE08FX4
Montgomery TX
No one wants to do it that way buts its doable and been done, like I said its not easy nor fun but could save you some dough.
Danbonzo
Redding,CT
Thanks
Do you have a lift or access to one? If so pull the cab. Royal PITA cab on
91turbogsx
Gardner MA
I do not have a lift. I could probably have access to one but I wouldn't want to tie up someone's bay if I were to run into a snag or something. I will buy one eventually but this project will most likely be done without one hopefully.
Dzchey21
wyoming
WE did it in the bowling green parking lot, it wasnt alot of fun thats for sure, i would recomend pulling the turbos and then pulling the up-pipes, can be done cab on and with the transmission in place, It CAN be done with the trubos in, but the fuel cooler and alot of bull **** hass to be moved.
ONe thing i would also recomend is cutting the egr pipe.
HOWEVER you can run the wastegate in place of the lower egr cooler with WOP wastegate kit.
bigrpowr
<How I Fly
what do you mean? i had a blast, thank rob for that.
Dzchey21
wyoming
yeah, your were having a good ole time while the iron mike haller and I blew two trucks apart in the parking lot to make it happen
Which reminds me you have to pull the down pipe to get the right side uppipe off
Erikclaw
Central CA
I can't believe it went down like that. LOL
BFT
southern cali
tranny out makes it easier to get to the bolts behind the turbo. but cab off makes you keep the profanity to a minimum.
also, drop some coin on some studs:poke:
91turbogsx
Gardner MA
Has anyone got any reviews on WOP's kit? Is it just an open dump? I already got rid of the EGR coolers and such (cab on) so mounting WOP's kit would be rather simple. But I do still need to replace the drivers side up-pipe at a minimum.
91turbogsx
Gardner MA
If I do lift the cab studs will be going in for sure.
Dzchey21
wyoming
it dumps to atmosphere, seams to work well if the gate is dialed right, since you have all that stuff out of the way that uppipe shouldnt be bad at all.
I would just do the drive pipe and a gate it probably will live
