Water Injection
Chrisf97305
Salem Or
How much water is injected? What is the GPM Nozzles that comes with most kits.
How do you know and what happens when to much water is injected?
silverpsd_06
Wellsville KS
It should all be controlled by the boost reference given to the controller and too much water injected will most likely hydrolock the motor cause it cannot dissipate the vapor prior to it reaching the cylinder and by the time you notice it.. you have most likely bent or snapped a rod. Start with the smallest nozzle you can to control your egt's
Chrisf97305
Salem Or
Thank you. That worked great. It was a great help. Now I know that I won't drown my engine when I hit the button.
