water leak
brown1
southern michigan
not sure this is the correct sub forum but i have water coming out of my grab handle for the first time. i have cab lights and a moonroof. what are some obvious things to check for. truck is a 13 and i have owned it for about 6 months and this is the first time this has happened.
Tom@BigTimeKustomz
Bayville, NJ
How does the door moulding look? I had a leak on my old POS Ram and it was coming through the door by the grab handle because the weather stripping was disintegrating.
Jonnylu
Cape cod
Sounds like sunroof drains are clogged if you have one..
Profuzz
I got lucky mine was the drain tube
