Weekend project
forcefed6.4ford
Medicine Hat... Again
In not doing dual fuellers this year but I open the truck up every spring. I don't need much more fuel for what I want. It's just to help get the turbos going a little easier, 4:30's will help tremendously. Plus now that I've seen what kind of project it would be to swap tips I can do it on days off easy.
powerstroked08
Pennsylvania
Looking good! Should be a nice setup. And I'm right there with you on being cheap and doing it cab on. I did all of my upgrades cab on as well. So cheers to another cab on mod man:toast:
RSK
Connecticut
Better. Getting too hard on the neck Morg?
I looked at the first pic and was thinking wtf is this. now I can see it...looks like you are hammering it out! can't wait to see videos of it done. I wish i had a garage to work on my truck. I have to pay 1000 to my mechanic to lift the cab, and he will do anything to the motor that doesn't require pulling the heads for that same 1000. so turbo's up pipes, manifolds. nozzles. then another 1000 to pull the heads or motor, send them to the machine shop get the checked out. and put stock gaskets back in and stud the heads and install hd push rods, valve springs and ti keepers and retainers. 1000 to fully pull the motor to drop it off at the machine shop to do pistons, rods, balancing. not terrible in my opinion. but enough of me. good luck and take video's and more pictures!
B585Ford
WV
I hate to be the one to point out the obvious, but you aint Canadian.
Csilva187
Knock on wood I lucked out also! Used the money for uppipes etc. Good luck, it's cool seeing other cab on projects.
