Weird noise
cbking
Minneapolis, MN
Truck is a 2008 F350 with 134,xxx miles on it. Today I notice that there was an odd noise coming from the front end. It sounds similar to BB's or rocks in a tin can. This noise is happen under 10 mph it is some noticeable both when turning and going straight. Might be just slight more noticeable turning. Truck is tuned and ******d. Doubt that matters though. Thanks for the help.
Tarheel_6.4L
Memphis, TN
Check your ball joints to see if it's time to replace them. I had a similar noise coming from my front end that only occurred when slowly moving forward, turning or in reverse. Had ball joints replaced and the problem was solved.
Lipka101
Maryland
Brakes. I get the same noise after my truck sits for a while. I need new rotors and chunks of rust come off and hit the shield.
Sent from my SM-N910V using Tapatalk
