- Joined
- May 22, 2011
- Messages
- 15,240
- Reaction score
- 1
well dang thats great then!!
thats what i was thinking but i thought drive pressure would be a little higher due to running two turbos
what do you mean?
most stock trucks w/o gate see 60+ .
I just dont think the changes of the stock re grind cam compared to stock are agressive enough to make a difference to need special tuning
Yea both, who made the one that did not spec out and who made the one you currently have?
So that's why you sent it back. LOL The EDE stage 1 cam is almost identical to the Colt Cam. Each is barely larger than stock. The cam Bigr has had excellent luck with was the same grind as the cam you returned.
Well I'm not going to tell who the first one was from because they are a vendor and do make tons of great stuff and I'm sure they had someone make it for them and I don't know who that would be. As far as the one I bought and put in my truck it was from Colt Cams.
Why did you change it and call it the same thing then? LOL LOL LOL Tadd we already went through this once why can't you let it die.
Don't colt cams make the regrind for rcd ???
