Well its time for a clutch
hunter scar
I going to have to install a clutch in my 2002. Im leaning towards the valair Kevlar/ ceramic clutch. Anbody else running one? I like south bend clutch's but I don't like the thoughts of a Kevlar bushing instead of a regular pilot bearing. Any reviews or thoughts please chime in, Thanks Hunter
97stoker350
south central pa
Got the valair ceramic/Kevlar in mine. It holds well. It is a little jumpy though especially in reverse. But its the only clutch I've ever used so can't compare to any other
cbf9703
I'll never run another south bend after an issue years ago. Basically said there was no way a Ford made enough power to hurt it, actually asked if we were sure it wasn't a Dodge. :doh:
I know plenty of people that run them, I just won't anymore.
CarportMechanic
WA
Really like my south bend. Very smooth and has a nice soft pedal. Grabs really well also. I have no experience with any other brand clutch though.
CarportMechanic
WA
Did you guys south bend come with the Kevlar pilot bushing?
Yes. I even had to replace my clutch fork about 10K after I installed my clutch and the pilot still looked great. Dont make the same mistake I made, Order yourself a new clutch fork from Ford if you still have the stock one in there. When you install an upgraded clutch the stock forks break pretty easily. Its $50 from Ford. Can probably get one cheaper online but I needed one same day.
Ive seen a few threads where people will have the flywheel machined to accept a ball bearing pilot. I dont know the specifics of this though.
manual6.0
Greenville, SC
I have a valair kevlar/ceramic clutch in my 2005 6.0 zf6
pros: never slipped once yet(should be good up to 500 hp if im correct), slips while taking off so its not too jumpy, pretty good balance between holding power and driveability
Cons: noisy when taking off, its not easy on the leg in traffic, tough getting into reverse sometimes
Id like to hear other peoples thoughts and opinions about this clutch if they have had one....??
Also, any one have issues when its real hot out 80-90 degrees and having to put the pedal to the floor to get the truck in gear?
**I have replaced the stock clutch pedal bushings since they wear out prematurely and can lead to the problem above
http://www.ebay.com/itm/FORD-Clutch...too-/251907196267?hash=item3aa6d6c56b&vxp=mtr
NyCowboy87
Arkport, N.Y.
I just put one in my truck last night and drove it about 2 miles. Not quite as smooth as the stock clutch but not bad at all. Was going to drive it to work today but we got a few inches of snow last night so they salted the roads, decided to take my ranger instead.
ju015dd
Tallahassee, FL
the south bend dd comes with a nice roller bearing pilot, and so nice and easy on the pedal. Very soft and easy on the leg in traffic.
hunter scar
How noisy is this valair clutch? I need to now what to expect, so I don't think it's coming apart lol
97stoker350
south central pa
Well mines only noisy if I lug it down low. Other than that its nothing you can't get used to if it even makes noise at all. I can't even tell anymore
hunter scar
Good deal I will get used to it over time ,what horsepower are you running with it?
