6.4 Stroker
When your comparing your dyno numbers to the track are you using corrected numbers that most dynos produce.
You have think weight is not everything. If you are comparing to a stock truck as in height wheels and tires can cause time also. Skinny tires on my car were a few tenths compared to the normal wheel and tires. Not worth it for me so I didn't run them because the car squirmed at the big end. For me 1/8 mile is hard to tell HP problems because you don't the the time and MPH difference between 1/8 and 1/4. But both having a 71 big turbo shouldn't that mean the HP is about the same. Seems like you have a lot of fuel for those chargers.
Sent from the bat phone near a drilling rig.
I do agree it's too much fuel for those little drop-ins. I wouldn't run such a high PW tune if it didn't make more power.
I have a set of platinum 20s with Michelin I've tired aswell. I gained 0.10 MPH on my trap speed swapping them out. I also agree it's tough to judge of a eighth mile time. I think I'll try to find a close 1/4 soon so I can see the full picture.
Since I've been around 6.4s I've always herd you need a gate if you spray, or add fuel. So why can't I exceed 68 even with the gate fully closed?
