what do you monitor?
sleeps
Virginia Beach, Virginia
Just curious to see what people monitor on their trucks and what with. What do you have setup to monitor on your device like the insight and what do you have individual gauges for? Seems everyone is different.
Coxey Diesel
Athens Alabama
I've got EGT, boost, and trans temp on the column and EOT, ECT, EBP, ficm voltage, and trans gear on the CTS. Should have a fuel pressure gauge on the column when it gets delivered.
Zmann
My insight has
boost
EOT
ECT
batt voltage
exhaust back pressure , this parameter I change a lot some days its trans temp or whatever I may want to keep an eye on
FICM output
I have a standalone digital gauge with alarm for EGT and one for Fuel PSI
SSpeeDEMONSS
6mi from the beach, SoCal
Analog are boost, pyro, trans, fuel pressure, and voltage. The quad commander had ECT, boost, and something else. I want ECT, EOT, and drive pressure when it's back on the road.
Garrett
probably getting paid at work to post this from my bionic
Jeremyleggett07
Katy, Tx.
Edge Insight monitor FICM voltage...tranny temp....EOT/ECT....boost.... Speed-o.....gear selection TC lock.... Sometimes batter voltage
Mar00n6liter
SCT Live wire TS. Boost, EOT, ECT, FICM voltage, battery voltage. I don't have EGT but I can get a sensor and hook it up but you can monitor , load, accelerator position gear injector pulse width and a whole bunch of other stuff you probably don't necessarily need
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
Koda22
Ruidoso, NM
I got boost, egt, tranny, and volt on the pillar...on my edge I got ect, eot, speed, and the fourth one varies depending on how I feel....
Justin@DP-Tuner
When I drive the 6.0L I use the Infinity to monitor. I usually watch FICM voltage, ECT, EOT, TFT, MGP(boost), EGT, battery voltage, TQ converter lockup, gear selected, pedal position, VGT duty cycle(just for fun), and ICP.
Mixedbreed
Laramie, Wy
On my LiveWire I have boost, EGT, TFT, EOT, ECT, and battery voltage
I would love to get a different tuner and measure stuff like FICM and all that other cool stuff but I ain't got the money yet
Lilpooh
Sassamansville, PA
I use DashBoss, too many to list, I can watch 24 PID'S with a swipe of the screen. The main PID's I monitor are ECT,EOT, FICMv, ICPv, ICP Calc PSI (true ICP psi when tuned). Other than that, the rest are used for trouble shooting.
