What Do You Tow?
TrailerHauler
Michigan
Trailer hauler I love that trailer what are the specs on it. If you don't mind me askin.
8.5' x 32' lowboy with a 2' dovetail, triple 7k brake axles with drive over fenders, front sealed and locking storage box. They make a nice trailer, I've been very happy with it so far.
If you have a chance could you show how you attached the pipe stakes. Id like to make some for my trailer. Looks like yours are made from channel iron?
It's just 3" c-channel with a piece of angle iron welded to the side to keep them from falling through the stake pockets they sit in.
valvetick
The race trailer was the only option to fit a few rzr's or bikes and a UTV etc. while having living quarters up front.
I stopped in @ the scale last week fully loaded with all the toys and tanks full of water and fuel and its 24k gcw loaded and 19,500 empty
Jomax
Arizona
That's actually not bad at all. I figured it would've been heavier 26k area
valvetick
Ya my SRW 350 has a rear GAWR of 7k so that is the first limit I hit while hauling the trailer. It's lighter then I expected compared to some of the toy haulers guys are lugging around
Truck is 8k by itself so trailer isn't too bad
Ipkyss
What size is that toy hauler? Picking up a 40ft pace with 20ft garage this weekend for a friend. I was expecting it to be a lot heavier then that.
Nice set up
mandkole
Northwest
7k is a lot of pin weight for those tires. I wanted a similar setup as that Vintage, but it really maxes me out when its loaded for a race and camping (water, etc). Youre really in DRW territory there.
valvetick
It's 44'
Yes my rear GAWR is 7k being a SRW f350 so I am right at the max. When I weighed it last I filled the fresh water tank and had both gray and black tanks completely full as well as the garage full of toys and tools to get a max weight. I don't travel with both gray and black tanks full and always have tools and toys in the garage which pulls some pin weight.
Unloaded with nothing in the garage I'm at 6980 axle weight and at 7100 loaded with max water and garage full. Without the gray and black and garage loaded it sits around 6000-6500 rear axle weight. So it's all about how I load the trailer to keep the weights in check. I always stop at the CAT scale to check it's cheap insurance since I am pushing the limit of a SRW.
Ipkyss
I put 7200lbs on the rear tires of my srw and it tows extremely well. My only reason I could say a drw would be nice would be for safety margin of a flat rear tire. The truck has great control. I did upgrade the tires to toyo a/t with a 4080 load capacity
valvetick
I'm running Toyos as well when I got my new set. Mine tows fine and very stable just try to keep it under the limit to play it safe
jimmystoys
Surrey, BC
It tows very well. Good tires, traction bars, shocks and air bags. I think the stance helps lots too.:thumbsup:
farm boy
Rosharon, TX
The old Dinosaur pulled it 70+ mph. Stopping was another story...
trailer weighs 9k empty, plus another 17k in hay. :fordoval:
