Pockets
Villa Rica, Ga
Well I had to get jumped off again today so I picked up some DieHard Platinum P2s this afternoon. I got them for $481. so that not too bad....
The old Bosch I pulled out were from July 13' so hopefully these will last longer.
VetteD_SiN
just got these (pmf hd draglink, hd tackbar). never got around to installing them. probably tomorrow.
vcassens
Godfrey,il
Finally started it tonight now that the manual transmission is in. I ann happy that it actually started the first time so i hit the wiring right the first time. Even the safety switch on the clutch pedal works as it should. Now tomorrow i will get the new drive shaft and get it installed then fill the trans and transfer case finish up the interior stuff and take it for a drive to see if the cruise control works.
Sent from my SM-N910P using Tapatalk
dieseltron
got my stupid broke manifold bolts out
new oil pan time
vcassens
Godfrey,il
Put the ol girl to work fir the first time since the auto to manual swap. Not a lot of weight but a good amount of wind resistance there are 28 4x8 sheets of 1.5 inch insulation and 8 bundles total. The truck definitely needs tuned it will start cutting out like it is running out of fuel with aby over 3/4 throttle which is common after doing the swap without a tuner
lincolnlocker
Central Michigan
right on man.. totally different animal with the swap aint it?
live life full throttle
vcassens
Godfrey,il
meh, you just need to drive the right 4r setup.
That may be but fir this particular truck i thing going manual was the best decision since it will be towing that trailer a lot. When i get a new truck if i keep this one it probably won't get unhooked much at all
