What Size Lift?
Garbs
Looking to run 20x12's with a -44 offset with some 35x12.5 tires. What size lift would be needed to run that on my 1999 F-250? If anyone has photos of that setup please post them. Also if you have 33's post as well. Wouldn't mind getting a look at those as well if the lift needed and possible rubbing is too much in my mind. Thanks!
atthelake27
Oklahoma
You could possibly get by with a leveling kit and a lot of trimming the fender liner might have to adjust the bumper. I have 12 wide on my 2016 same offset and have a 4.5 lift and still had to space my bumper out 1/2". Just depends on how much trimming you want to do. If you went with 33's I'm sure a leveling kit would be just fine.
Koda22
Ruidoso, NM
I would think a 4inch would work....might rub a little but I wouldn't think bad, if you stick with 33s a leveling kit should do it....
Hope by the end of the year that's how my truck will be sitting...4inch lift 22x12 and 35s
Garbs
I think I am going to do a 20x12 -44 offset with 35's with a 4 inch lift
diezelfreak
Manchesthair tn
Here is mine with a 2" leveling kit with a 3" block in the rear. Back sits up 1/4" higher. Mine rubs on the inner fender when turning.
