What to do with a worn compressor wheel?
giannid
Chardon Ohio
Doing an engine install and I noticed the vanes on the intake side are a little dusted. They're still all there but definitely seen some dust through them. the turbo looks like it's newer and there's very little end play in the shaft. Can I just replace the wheel with an aftermarket wheel or do I need to replace the entire turbo. Seemed like the turbo spooled up well before, I'm just afraid the vanes are thin and may eventually break off and enter the intake.
Magnum PD
VA
How much slap when you try to move the wheel around in the turbo?
Arisley
Arlington, Texas
Any end play, I would either rebuild or replace the turbo.
Why spend the money to rebuild a motor just to have a wore out turbo, (that probably trashed the motor in the first place), trash another motor.
golfer
Arisley- pretty sure this is just a used t444e engine.
If you ran a compression test on the engine, then plop a new wheel in it and roll.
If you didn't run a compression test, the worn wheel would have been a big red flag on choosing that engine as a candidate
Sent from my DynaTAC
