What's cylinder 8 telling me
space_heretic
Well I pulled apart my driver side head because of a glow plug mishap. My other cylinders on this bank look good. But 8 has what looks like rust. I have been loosing coolant and found white residue under valve cover. Picture with the light is cylinder 4.
I did have it scanned prior 8 failed but I find I have the original injector in there so it was possibly the cause. Otherwise truck was good.
Sent from my iPhone using Tapatalk - now Free
space_heretic
I guess it looked worse than it was. I figured a scotch brite pad and wd40 couldn't hurt so I very lightly scrubbed it. It just came off for the most part.
space_heretic
Well I inspected the headgasket and I could not see any signs of leakage or damage. Than again I don't look at them often so I may not know exactly what to look for. I looked at the head surface no signs of leakage except one suspicious spot but it was on cylinder 4 not 8 where my rust formed.
How does the coolant pass through the heads? Possibly next to intake runners?
2000wa250
Cracked or loosened cup.
Sent from my DROID BIONIC using Tapatalk 2
space_heretic
Thanks guys pulled passenger side head. Walls looked good taking the heads Monday hopefully they find a issue in there because I couldn't find obvious signs off failure on that head gasket either.
I also found a shop not terribly far away to get injectors tested.
Only thing I need is a new evbp tube and a damn bearing for one rocker arm. It fell somewhere on the frame or trans.
