Wheel size/offset question
hoosiers16
I'm wanting to get 37x12.5 or 13.5 tires, as for wheels I'm thinking 20x10's with either a -12 or -24 offset.. Does anybody have a setup like one of these combinations with or without a fender flare?
Dantron
Texas
Here's my previous setup with 6 inch lift, 37x13.5x20 tires, and 20x10 wheels...
Dantron
Texas
You won't be able to fit more than -24 offset on 6 inches of lift without substantial rub.
getstroked27
Friendship, MD
true story there.... went from 20x10 with 37x13.50 on an 8" to 22x14 with 35.12.50 and 1" spacers and I'm damn near rubbing.... offset is king!
Brad.S.19
Maine
you'll need 6" of lift minimum.
Saw a 13 kr short bed on a icon 3.5" ala's and 6" ouo traction blocks stock 20s 37x13.50 toyo mt. If you put a 4.5" compared to the 6" set up based on the bs and offset.
Sent while speeding pushing little cars of the road and eating a burger.
hoosiers16
so if I were to have a 6" lift and put on 37x13.5 tires with 20x10 -12mm offset they would rub? Sorry I'm new to this and the numbers don't make much sense to me.. if so then what about 12.5w tires?
Dantron
Texas
You wouldn't rub on the wheel well or bumper like you would with -44. I meant "more" as in more negative of an offset, such as -44 or -76. I know people can rub on the inner workings without enough negative offset, but I think the setup you described should be fine. I would go with the -24 offset though for a better looking stance...
