When did you have a HPOP line fail?
onebad7.3
MI
How many miles were on your truck when a hpop line blew? I'm always afraid of getting stranded somewhere. I like to replace things before they go bad. But the hpop lines aren't cheap and I don't want to replaced them if I don't have to.
JD3020
Farmersville/Dayton, Oh
So far we haven't had a HPOP line fail, knock on wood. My truck is at 190k, old OBS was 230k, uncles is over 120k, and some friends with well over 200k. We've had some leaks at the fittings but never one blown.
To be honest i've never heard of one blowing, other than some aftermarket lines and HPO crossovers. How many miles are on your truck?
94.5 Stroker
Lincoln, Nebraska
I blew one around 218k I think with a fresh SRP1 on it, split the line going to the right head. No doubt they ain't cheap, I think mine were almost $300 from Ford.
Denver
America
If its not broke don't fix it. At 97K you shouldn't have to worry about anything. If anything I would be saving pennies for a water pump.
bluedge8
Champlin MN
had mine fail around 170k, didn't have a "hole" in it but the connection failed and the truck quit, oil everwhere, and I paid way less than $300 for both lines from ford.
onebad7.3
MI
Replaced the water pump already, add a coolant filter also.
Austin, Tx
352k miles on mine, no blown lines. I have blown 2 o-rings and, 2 HPOP gaskets, and a fuel return line that goes from the head to the FPR.
DEEZUZ
NO PUKESTERS
NWI
Worked on one that the line blew right around 130k. the line itself blew apart. Not from the fitting....
