Which e-fuel system and hpop should i go with?
Mad Max
in, out and all around the matrix you live in
In the near future im planning on putting in 250/200cc injectors in my 95 7.3. Im wondering which e-fuel system would be the best to use? I dont know anything about the carson stauffer fuel system. I've heard good things about dieselsites CPR fuel system but not sure if it would support 250/200 injectors since from what i've reasearched its basicially running a stock super duty fuel pump. Now the beans fuel system i've heard will run up to 250cc injectors, my question is with 250/200 will their fuel system support it, or do i need to get a dual pump setup?
as for the hpop will the stealth stock replacement hpop cover my oil needs or do i need to get a stage 2 or 3 hpop?
just trying to get everything lined out for now so i know what i will need and what i dont need.
Whytry
Memphis IN
I think a srp1 will run 250/200 but I would check on that. For a fuel system I personal would build my own. It isn't that hard and you get the best of everything. Know if you want to buy a kit I would go with beans.
